Cooling fan running with ignition on traced wiring loom, swapped uch upc and column fault still the same
Any suggestions?
191527
you have changed ECU as well? or
Refit your Original Under bonnet fuse box (upc)
Discussion Starter · #5 ·
Yes this is refitted but still faulting I have a low voltage to the injector loom but this stayed the same if I give a 12 volt feed to the loom it starts but if I leave it like this for a couple of days it will not run until I remove the feed but then starts for a few days before faulting again grrrrrr
You don't say what vehicle this is? It might help to know the model, year and engine.
There are a lot of computer supply voltage errors listed there - I would perform a charge-current test on the battery first and replace if necessary. If a recharge is required, 6 hours minimum.
What was the reason for changing all the ECUs? Seems like a drastic course of action...
Also, can you explain this quote a bit more clearly?
(One problem with a long list of DTCs like that is that it isn't clear how many of these codes are in fact relevant. I would clear all codes (having noted them, of course) and restest the system to see if any recur.)
Discussion Starter · #7 ·
Yes I agree with you, but as always I have inherited this job.
The battery has passed a digital drop test and the parts swapped were from a running donor as it was pointing towards the column being the fault and as you know they have to be a matching set.
As the post states 2011 1.6 clio cheers 🥂
