Hi all,
Recently being experiencing the car going into limp mode (but no orange spanner light on the dashboard). Took it to a garage with Canclip who advised the fault was to do with the Lambda sensor. He wasn't sure if there were 2 Lambda's on the car. Anyway, I took the lambda out near the turbo exit, which was pretty sooted up, I cleaned is with carb clean (outside of probe and through the holes within the probe). Took it for a test drive and the problem is still there. When driving a simple switch off and switch back on clears the 'fault', so I'm pretty sure it doesn't need clearing via Canclip. My question to the more knowledgeable folk is, is there a 2nd lambda probe somewhere underneath the car??
Thanks Jamie
