Hi everyone,
The mother in law hit her RHS mirror.
Can anyone identify whether I need a whole new mirror assembly or whether I can just replace the broken parts? Any suggestions would be highly appreciated.
Brilliant! Great answer. That helps a lot so thank you. I am in Australia here so will need to search more locally but thank you again. Part numbers help too, thanks again.You probably need the entire assembly...they are not cheap either! Look at a breakers yard first otherwise UK pricing is around £180 + VAT + shipping!
Breakers yards will charge around £45 + shipping for the complete unit.
SYNETIQ
There are the part numbers for a RHD MK3 Coupe Megane:
963020182R External Mirror Passenger Side
Driver side = 963010193R
I suspect from the pics your car is the 4 door Megane. This you will need to search for the part no:
Renault | Parts Catalogs | PartSouq
BTW Coupe 3 door & 5 door Megane MK3 are not interchangeable either the angle is different it will never fit. You might be able to get away with just replacing the broken parts but do not think they sell the bottom part of the assembly so unless you can fill the damage it would fill with water which might seep into the chassis & or door assembly at some stage causing more damage.
