Good evening all, strange one here, I have the the traction control light and spanner light come on intermittent, the fault code comes up as DF0025 "Neutral position switch circuit malfunction", its a manual gearbox.
We have just fitted a reconditioned gear box and new clutch.
Any help appreciated.
Gear box switch
Yours could have two
One on top of the gearbox, ( Neutral switch ) One above rear N/S drive shaft (reverse light(s))
check you have put the correct switch in
  • Like
Reactions: Don Comm
Do you still have your old box,?
not found a plug under the battery that you dont know where it goes
Checked there is no plug off the Gearbox
