Hi. Is it realisically possible to replae the top ball joint on a 05 master van with a manualestactio tool while the arm is still on the vehicle?
20200730_143121.jpg I understand this model is a different set up to the 2.4lt later model)
( View attachment 185786 View attachment 185786 I understand this model is a different set up to the 2.4lt later model)
Hello.
Yes can be removed with a proper ball joint removal tools. Not necessary to remove entire arm at all.
Applied pressure with the correct removal tool will press the ball joint in situ within 10 minutes. I could send to you pic of the exact type of removal tool required. I replaced all of my ball joints and month ago .
