hiya gota 51 plate clio dynamic 1200 16v(d4f) ,starts but revs r up an down ,then cuts out ,pluged computor in ,brought up code ,po115 engine coolant sensor any help would be great thanks
Have you checked the engine coolant temp sensor?
Also the fault code is generic and non-Renault specific so it may be totally erroneous.
the coolant sensor is working. i dont think the code means much. the coil light comes on the dash which is and electrical fualt so i change the eng loom today still no luck tho.
