1 - 1 of 1 Posts
Hi all recently bought a renault scenic dti, thought it was just the power steering pum had failed but upon closer inspection it appears that the metal pipe that i am assuming is the return feed to the reservoir has a hole/split in it, almost certainly the reason the pump failed in the first place i would have thought,
rang renault and they say its approx £60 for the pipe, but can i cut the split out and use some rubber hose and jubilee clips to rejoin the pipe? its not the one that comes direct from the pump its the one that i assume runs around the car or under the car,
i dont seem to be able to find any in local breakers or on ebay?
am i also right in thinking that the return feed is the low pressure side?
any help much appreciated
Cheers
Tez p
1 - 1 of 1 Posts
