Starting problem with Scenic 51 when hot. Crank shaft TDC changed still have the problem. wait 45mins to cool down starts ok Help please
Hello I have heard of a similar problem. What I would suggest is do a compression test when cold and do similar test when engine stops . Would prob mean leaving it in to garage but make sure they do as you ask. Reason for this is when engine hot it expands leaving gap between cylinder bore and piston hence no compression then when cooler say 45 min later it contracts and compression back. Hope this helps
