I have a 1.9 dci scenic (52) which has a real problem starting.
The engine turns over but will not fire, eventually will go but normaly need to put jump leads on as by the time you keep cranking the battery is flat. It dosent matter if the car is cold or warm. after started runs fine, and if you re-start not normally a problem until it has been sitting for a few hours then problem returns. I have replaced the following and there has been no change.
Crankshaft sensor, glow plugs and the glow control relay.
Now lost on where to look next - any ideas? Mike
