1 - 10 of 10 Posts
Hi all after some advice please. I have a 54 plate dynamique I can lock doors deadlock too but my alarm does not seem to be activating. I can leave car locked with window open but alarm won't trigger. Any advice please
Is the IMMO light flashing , have you had the car long..?
Sure these have an alarm with a battery inside, this could now be shot and not accepting a charge, but let someone confirm this first..
Immobiliser light Red flashing light on the dash when the car is locked!
So immo is working,..
Not had anything done recently,
Interior lights working,, does sound like the battery in the siren has failed..
But would rather someone confirms this ..
Ok we seem to be 1 step closer. If I leave window open but car single locked and open door from inside the alarm goes off. But if I lock car and sit there or leave window open the alarm won't activate. Any ideas?
When the car is deadlocked, then the car cannot be opened from inside,, try by pulling the handle..
Now when single locked it can still be opened from inside.
So could be how its designed and operates..
Just see if this works on your car as it sounds like it should..
Send your windows down, now get out the car, lock the car, with the button.
Then lock the door again with the button, but hold the button in.
See if the windows now auto close..
1 - 10 of 10 Posts
