hi everyone i am getting a noise in top gear(5 speed gearbox) it only happens between about 1500 to 2000 rpm,the rest of the time its fine. i checked the oil and its ok. any ideas?????
hi m8,:) im not taking the pe pe but it could just be that your changing into 5th to early, 1500 rpm is quite low for top gear, and you will also be labouring the box and engine which is not to good.
dont get me wrong though m8 if your not sure get it checked as you cant realy tell over the net and it will give you peace of mind.
good luck alex:)
Erm, my lag will quite happily accelerate from 1500rpm in 5th and 6th (along a flat surface), but it is a dci...the op doesnt state what car he has.
