Hi all,
I've recently brought a 65 Captur and was wondering if it has DAB capability at all?
I've seen that all new Capturs have DAB as standard, aside from entry level ones?
I don't know if mine is entry level or not? I don't even know what entry level is??
Any help would be greatly appreciated!
you will need to find if DAB was ever an option on the 65 plate car, I doubt it, but there is no harm checking first, speak to your local renault dealer and ask them, if not then you are in the realms of replacing your Renault stereo with an after market DAB System, which is not that difficult because I could do it and I wrote a tutorial on how to do it keeping your steering wheel controls working as they should:-
I know this isnt a DAB stereo, but all the steps are the same except you will have to fit a DAB antenna as well, get a powered one and splice the power from the red wire going to the back of the stereo, so it only powers on when the stereo is powered on
