hi, new to this so bear with me ,
i have a kangoo van with a starting problem, sometimes it go's first time , and later the same day i could sit for ten mins turning it on and off and turning it over ... it always starts eventually but is really getting frustrating, there is no pattern or knack to starting it... the light on the dash for the imobiliser should stay on when you try to start (?) and flash when imobilised , but sometimes the light will flash and still start....
can anyone help before i take it to a main dealer>????
glow plugs have been checked and i have been told they have good continuity..
hi,check the glow plug relay,sounds like the same problem i had a year ago-it's the block with wires coming out of it bolted to the battery box next to the fuel filter,i got a new 1 and it's started first time since then.
cheers ally, been getting really p***ed off with it, will get one and give it a try ,thanks.
