Hi all,
i have a 1987 trafic camper, the headlamps only work on full beam there is power going to the yellow wire but none to brown and orange at headlamp connection, hope you can advise many thanks
In my experience is usually the switch that causes this fault,you need to get a test light and check for a feed from the switch to the dipped beam.If you can check the continuity through the switch then this would tell you 100%,but you need to work out which wires and which pins do what to be sure.
I guess you've checked the obvious fuses and relays too?.
