1 - 8 of 8 Posts
I have decided to try to get my clio centeral locking working as when purchased it did not come with an IR key. I have a few questions regarding this
1. Will any IR key do? Does it have to be a renault one? Costs of the key, and the best place to get one
2. How is it programed? I have had a look around the forums and see that their are different codes and surgestions. using the central locking button etc which method will I use
3. Problems I may run into? any one done this and know of any problems that I may run into?
I have read the related topics here and got a knowledge base from this but was wondering if I can get some more direct information as I am on a small budget so would like to get it right first time (for a change)
Thanks in advance.
Let's be carefull out there
Did your car have CL originally ? Is there a CL reciever in the roof pod (behind the red window) . You could try a Renault IR key from a similar age and try the home programming tips in the Clio FAQ. If that does not work get a key / reciever pair from a breaker, they should only be around £20 tops.
Ok, yes I have the reciever consol just need the key. Is it just as cheap getting a new key? as the ones I have seen are pretty well warn. What code would you recomend? using that website with the software or trying the lock unlock and start up routine?
Ok thanks for that I will get a key and try out each routine untill one works. I will feedback when Its a sucess
Got the key and gone through the procedure on that website. I got a code and tried holding down the central locking button but nothing happened. No dash lights flashed etc. Any other ways I could enter in this code? Thanks in advance
Anyone had any ideas on this? I have been monitoring all the posts on the site over the last days and tried what is said. Is it possible to reprogram it or is it not?
Will a renault specialist be able to do this? any one got any ideas, surgestions etc
1 - 8 of 8 Posts
