Any ideas.....gas struts for the rear window keep popping out......replaced with new ones and exactly the same problem. Tried adjusting the ball joins on the window...still no differnt suspect need new ball joints too?
Hi, have the connections been cross-threaded? It may be possible to use some loctite heavy duty adhesive to bond them together.
Paul:)
Thanks for the sggestion, the strut has a nylon socket which attaches to a steel ball join on the window
