Hello All,
I have a 97 1.4 Manual Megane with electronic speedo. Unfortunatly the speedo has stopped working and the EML has come on. I noticed in the engine compartment an exposed damaged sensor which I think is the speedo sensor. See pictures below.
http://www.brownjl.co.uk/speedo/
I am hoping to aquire a new sensor tomorrow but I am having trouble removing this one. I heard there are two types one that just pull out and one with a clip, I can't see a clip and Ive tried giving it a tug and it wont move :S. Can anyone offer any advice on removing it please?
Once i have removed this is just a matter of pushing a new one in?
Cheers
James
I originally accidently posted my request for help in the knowledge base instead of here :S I will update that post with a how to fix with pictures once ive solved my problem.
Discussion Starter #2
Just an Update
Well there is a pin which easily pulled out, then I could pull the sensor out...
I got a replacement from Renault looked ever so slightly different but they did say it would fit it had just been improved.
Now here is my problem, I have tried pushing it back in but it wont go all the way in I can still slightly see the top rubber oil seal I dont want to push it any harded and break it, so any hints on this?
Tried the car anyway and the speedo is now working but "slowly" - so i think it is almost there, just got to get the pin back in....
Cheers,
James
Looks like ill have to take this to renault, unless anyone can sugest anywhere that will sort it in the lancaster area?
I cant seem to get it seated correctly to get the pin in, looks like its producing from the gearbox a couple of mil more that the old one....
Thanks anyway
James
Banned
did you manage to sort this problem and did changing sensor cure it?
Yeah it seemed to solve it just a matter of a little more presure to see it home. Not sure how well it lasted though as I upgraded it to a laguna a week later..
Cheers,
James
Banned
how much did you pay for the sensor as mine miraculously fixed itself now its gone again so def think its the sensor
ISorry can't really remember, i think it was less than £30... very expensive for what it is though....
James
