Hi, Thansk in advance for your help. I have a megane 2.0 8v coupe. After being left for 2 weeks unlocked in a garage, it will now not start. I have change TDC sensor, it then ran for 5 mins and then stopped, every time I started it ran and then stopped. Advice told me to check relays, located correct relay, swapped for another nearly identical from a clio it then ran but with fuel pump switching on and off, checked relay in the clio and worked all ok. Now after leaving car for 2 days it wont' start. have by-passed relay so fuel pump stays on but still will not start. HELP
