Can anyone shed some light on this please,when you start the car up all is fine,then after a couple of mins the ESP FAULT comes up on the dash,then few more mins later ABS light comes on.
Car drives perfect,so what can the fault be???
Thanks Chris
One of the most common causes of ABS and ESP faults is down to faulty ABS sensors so it may be worth having then checked out.
Have you actually tested the brakes in a safe area to ensure the wheels don't lock under heavy braking?:)
Discussion Starter · #3 ·
Not taken the wheels off yet,but are the sensors attached to what i see is a wire running to near the brake caliphers??
You really need to run diagnostic to see which wheel sensor is faulty. fingers crossed it will be a wheel sensor otherwise you are looking at a new abs pump which will cost over a grand.
