Hi the new wheel bearing is the same on both sides apart from the No's and stamped on one side,what i need to know is can it then indeed be put in any way round because its the same?????I always thought that the magnet on the ABS sensor worked with it but the sensor does not line up with the bearing it lines up with the teeth on the shaft when it is all back in the right place, your help would be grateful cheers all the best Donald.
i think its parrellel so make sure you can see the numbers as chris m said.:)
Thanks guys i was also told if it was put in the wrong way my ABS light would stay on all the time:crazy:talk soon all the best Donald
