Hi everyone.
I'm looking at installing an induction kit to my Clio Rip Curl 2007 and im wondering how i access the air box and remove it?
Clips? Screws? Any help or pictures appreciated.
Sexy at 71 super mod..
Undo the clip with a screw driver holding air box to throttle body..pull off hose in the same location..now you need to squeeze the air inlet tube at the slam panel and pull back to release that ..then if you look at the air box you will see it held on by some pegs that push into rubber grommets ..so you just grab the left hand side of the box and the right hand side of the box while pushing to the right to pull the air box off the throttle body..then lift up and it should be off..
