Hello
Does anyone know how to correctly adjust gear linkage on a Megane 3, 6 speed manual gearbox (TL4 gearbox). I (unnecessarily) disconnected the right hand side cable at the gearstick end (held in with a white clamp) when removing the gear lever. How do I properly adjust this again? (NB it's on a left hand drive, but I guess that does not make a difference).
Not sure on the 6 spd box.
5 spd one
Loosen off the linkage
Engage 5th gear (underneath the car)
Select 5th on the gear stick
Adjust / connect linkage to suit
re-try the gears from in the car
Maybe try that, if not, try 6th gear position.
