I have a 1990 Renault 5 and want to fit an aftermarket rev counter (52mm dia to fit in a pod).
The problem is I can't find one that will work.
It needs to be negative earth, but connect to an electronic module (NOT to a coil).
Most of the ones I've seen available only work with a conventional coil - which my car doesn't have.
Does anyone know a make/model I can use?
I've already bought one that was wired up - only to find it didn't work... and I don't want to waste more ££££.
Thanks!
It might be worth phoning or visiting the website of Demon Tweeks.They are a company who specialise in motor sport equipment and they used to do a whole range of gauges.
I'll check their website out and get back to you.:)
Revcounter
Great; thanks. Will call them tomorrow and see if it's compatible. I rang six online accessories companies in the last couple of days and they either a) didn't know or b) didn't think their particular stocked items worked with an electronic coil. Demon Tweeks might be my last chance!Mark
