Hi,have a laguna 1.9dci 2001 and the air con has never worked since ive had it 8 mths ago.When you press the button to turn it on,the orange light on the switch illuminates but you get nothing,ie you dont feel the engine having to work harder when air con normally cuts in.A friend recons its the compressor at fault..any ideas..cheers
ps havent had a response as to why my lag doesnt go into 1st gear after a bit of panicking on my part when i kept trying to stall car at 4000rpm after the turbo failed and maybe was a bit rough on the gears.any ideas here would be much appreciated too
hi m8:) your aircon fault may be because there is no gas in the system,(most common) take it to an aircon specialist to have it checked for leaks and regased.also if your not sure about if its working or not somtimes the pollen fillter is full a gumf and not alowing any cold air through
as to your geerbox, you said you were forcing it into gear, check the gearlinkage first to see if its moved or bent slightly, if they are ok then you can suspect the box.
i hope this helps you in someway bud and good luck:)
regards alex
thx for quick reply alex21,ive taken note of your points and ill act on them at the 1st opportunity.Ill let u know the outcome..cheers
