Anyone know where I can get an air con pipe for my 2001 renault megane 1.6 petrol mk1? Renault dont do them any more and none on ebay. There is a special piece on the opposite end to the compressor which fastens to an alloy block....my pipe Is broken....part number 8200154981
If it is only the pipe broken, you should be able to find a coupler to mend it.
Or it is search ebay or specialist Renault scrappers
Discussion Starter · #3 ·
Sadly, I have followed all the routes you suggest - pipe was broken off the alloy connecting block, so no join possible. Searched google / ebay for part number - no joy. Had pipe welded by specialist but still leaks......any other ideas???
Discussion Starter · #5 ·
I need a new or second hand air con pipe for renault megane mark 1 2001 part 8200154981. It is the one which goes from compressor to a block on the bulkhead. The part IS DISCONTINUED by Renault, so I can't get on from the Squealers! Anyone any ideas? It is broken near the alloy block which holds it and the other pipe to the block on the bulkhead. Only the one with this part number seems to do the job. Any ideas??
