1 - 11 of 11 Posts
Could anyone tell me were to connect the canister for recharging the AIRCON system.?
I have had aquick look under the bonnet and the only place That looks about right is the under a cover next to the power steering resi.
Any help would be much app.....
Sorry, I cannot help with your question but would ask whether you are using the Halfords DIY kit. Reason I ask is because I have heard that lots of people have problems with the air con after DIY'ing with it, least of all an air con pump chatter - something to do with Renault using thicker stuff??
My advise would be to pay an expert, you could probably get it done for around £45.
As I said, sorry I cannot help with your post but thought I would add a warning!
Best of luck:)
Thanks for the tip .
I will try the yellow pages for my local firm if I cannot sort it.
Cheers
Our local Kwik Fit are running an air con re-gas promotion at the moment. Don't know the exact details but approx £45 for a regass - if no improvement ( ie air con isn't any colder than before) - you get your money back/don't pay.
Just been to Kwik Fit.
They have Re-charged my AC and done a system cleanse for £64.90 inc vat.
The AC seems to be OK and they have told me no Leaks found.
So I will see how it goes......:crazy:
My local Renault franchise are doing it for £69 at the moment not sure if this is a national promotion ?
Ottoman
Tourerman
Kwik Fit must have done a scam job on your car as their kits will not work on the Laguna 11 as their canister has to be used via the A/C low pressure connecter which Laguna 11s do not have.
Did they give you pressure readings of the A/C system for before and after recharge?
Discussion Starter #10 (Edited)
Yep
I must admit I thought they had the car a while (2hours).
But the aircon does feel to be a lot colder.
Computer readout 16Degc before regass 6degC after.
Pressure:-before
low port 1.9
high port
Pressure after
low port 5.4
high port 6.0
I hope that I have not been ripped off!!!
Can anbody else confirm that the above is true -not lagII compatible.
will keep all informed..
Hi Dave - are you not confusing Kwik-fit with Halfrauds own top up system. My local Renault dealer is currently advertising a full air-con service for £69 - looks like a national promotion. Ninety minutes to two hours seems to be the time required for a proper air-con service.:)
1 - 11 of 11 Posts
