1 - 9 of 9 Posts
I'm new here, so I hope I've done this right!:crazy:
I have a laguna II with climate control, (1st car I have with air con). Last summer the air con only worked occasionally, and in the end i took it to a main dealer-stealer who re-gassed it for about £70. It seems to have worked most of the winter for de-misting, though can't be too sure, but it has stopped working completely now. It doen't even make the characteristic noises etc that usually occur when the air con starts.
So far I have checked the fuse by the drivers' door and that is ok. Never having had a car with air con but usually ok with some DIY work (money forcing me to now!), is ther any diagnosis I can carry out? Also how often should a system be re-gassed? VERY reluctant to use the dealer!
Many thanks
Shadyfox
Hi iam not that clued up on air con but i would not use the dealer i would avoid them at all cost there are many companys in my area that will re gas the air con for around £30 i hope this helps all the best Donald
HI i have a renault scenic and the same happened to me the compressor just stopped working i had it regassed it worked for about 3 months and then stopped,i called out a mobile aircon specialist and he done a leak test on the system and it was deemed that i had a leak in one of the aircon pipes i had that replaced a a cost of £90 with regas after that it was fine.I hope this helps
Tourerman
Renault say it should be serviced every 2 years (regas)
thanks
Thanks Donald and Tara. I'll look for local air con specialist. The thought of sitting in a sweaty car this summer isn't 1 to relish..ha!
Paul
1 - 9 of 9 Posts
