HI,
I have a Renaultsport Twingo 133 that has the airbag sensor lights on from a kerb pump (how annoying!). Anyhow, trying to get the airbag ECU reset, but one problem...where the heck is the ECU? Had a cood rummage around and still cant find it. Can anyone let me know where the airbag ECU is in this model Twingo?
Many thanks
Scenic mk1ph2, RX4, ID35s11
the airbag ecu is located up under the aircon unit in the middle. you will need to connect a diags computer unit into the diags port and step through the settings to read the AIRBAG ECU then clear the codes, run diagnostics on and reactivate if no errors.
you just need to make sure you have the right equipment to run diags on it, not all units will work on renaults.
