I have a Lauguna II and the aircon had been working fine for a few months until today when the temperature got really hot.
The outside air temp guage said that it was -32 and no cold air came from the aircon, does anyone know what causes this ?
I had a similar problem when i first bought the car but when i took it back to the garage it wasn't a particularly hot day and worked perfectly !
Help !
I've just noticed this with mine!!
The aircon works perfectly from above 5 degrees, many times I've run it up to about 17 when sun has been beating through the windscreen etc and it's been icy cold. But the other day, it seemed to be cold out of one blower but warmer out of the others, did the same last week - just didn't get cold. Then yesterday icy cold again. :crazy:
It's as if it only works within a certain range, I know about the lower one (it doesn't work below 5) but maybe there's an upper limit ( thus rendering the system almost useless) :)
