Hi, there seems to be a large number of scenic owners experiencing all sorts of heating problems. Nowhere in the forum could i find any mention of a bleeding screw. It works like this:
The radiator is situated lower than the engine. This means that when you fill the radiator with water there is an area in the engine where air is trapped because this area is higher than the radiator. So when there was a problem and water had to be topped up extensively, the system must be bleeded while the engine is running to get rid of the trapped air. On my 1999 scenic 2.0 8 valve, the bleeding screw is situated on the thermostat housing. The screw is opened and some water together with air is expelled. Keep it open until no air is expelled and then close the screw.
Hope this helps somebody.
