1 - 1 of 1 Posts
Hi hope this is in the right place, tried doing a search prior to post but couldn't find one. I have a w reg Renault Clio 1.2 8 valve the problem is 9 times out of 10 when I turn it on there is a squeak noise for around 5-7 seconds then goes away, so I give an inspection of the alternator belt and the power steering belt, the power steering belt was snug however the alternator belt had slightly more play on it then it should and some of the edges on the belt were scuffed abit but the grooves felt ok. So would tightening the belt take the squeak away if so could anybody explain hoe to do this? Thanks, Dean p.s when opening or closing the front electric windows and you keep holding the switch after the window is fully open or closed s knocking noise starts.
1 - 1 of 1 Posts
