Car is a MkII Espace Petrol 2.0i.
Last few days with engine running and car stationary - initial quarter turn of Steering Wheel right or left causes several 3 or 4 Clicks apparently from the Steering Box as tested with Hand on Box.
After the initial quarter turn of Steering Wheel >> no more Clicks.
No apparent Clicks when driving - only when Stationary or just moving off.
Actual Steering completely smooth either at standstill or driving - no feeling of the Click etc up through to the Steering Wheel - but can be sensed with hand on Steering Box.
No Fluid Leaks or loss. No noice from Pump. Definitely not suspension or transmissions etc.
Anybody any thoughts?
Looks like I can still purchase a replacement Rack if I want.
Would like to keep the old 'War Horse' if possible - looking great since Vinyl Wrapping here and there.
Trying to assess costs etc as carried out much work on vehicle - runs on LPG - and just passed MOT etc.
Best Rgds to All.
Any play in the joints in the steering shaft or there pinch bolts.
are the steering rack bolts tight?
Discussion Starter · #3 ·
Yes been thinking further on this - I going to check all fixings next few days see if I can spot something - I suppose you could call the noise half between a Click and a Creaking.
From exploded parts diagram of typical Steering Box - I cannot see what would make the type of noise.I have - as I said previosuly Steering really good and firm and smooth.
Will get back either with success or failure ( Poem 'IF' )
Best Rgds
