Hi I have satnav and the clock is always wrong! I know you can set up in the setup menu, but everytime i get back in the car, its wrong again by an hour! I read in the manual that it is set by satnav system, is there anyway i can override this as its getting on my nerves now! lol also I like to set my clock a few minutes later so I get to work on time! but at least if i could get the hour right, that would be good!
thanks
There's probably an option to set 'daylight saving' somewhere. I'm guessing that you have it switched on when it should be off for this time of year.
well if theres a setting for daylight hours, i be dammed if i can find it! Ive been through all the options and havnt found anthing except to change the time which is usless cos when you start the car up again it reverts back again!
and I know suffolk is in the a**ehole of england but surley we must be on the same time as the rest of the uk lol :rofl:
Yes but we are talking french (like when everything goes metric for no obvious reason). This is ether man and highly volatile. Check through all your pages for options, including voices (which also change language on mine.) I take it your satnav is having no problems with satellites.
You haven't by any chance had the car transported (like on the Chunnel e.g.) with satnav off (why would you have it on in such a case?). According to the book, it takes some time to find out where it actually is after such transportation. The gps logo should be green if it knows where it is.
The code to access your expert mode pages is 4112 (I had to be reminded recently... Ta' H'ratio)
Good luck.
Hi vasso, thanks for that number, I will try looking there! well I havnt been abroad in it and yes the satnav does work fine, it doesnt have any problems finding satellites at all and the symbol is on green! this one has stumped me and the user manual is useless!
Sorry to hear you are still having problems.
The summertime theory is worth investigating.
As a matter of interest, have you tried changing cd and resetting to factory defaults? It is possible to reset but can't remember how; I have a Nuvi 360 which I use more often than the Carminat, so I've forgotten more than I can remember.... tut tut!!
