Hi guys.
I've been having an on going problem with my 2011 megane coupe 1.5dci.
Started a couple of years ago - "check anti pollution system" & "Check injection system". After googling etc I found it could relate to my MAF (the diog codes stated it was air related [low/high] etc) I changed my MAF twice now and this hasn't resolved the problem.
Since, I have unplugged my sensor connecting to the MAF and my car works fine. It no longer has the annoying jutter or the small phase of power loss.
However this seems to be a temp fix, and not the solve to the problem.
Can anyone out here advise what I can do to find the route of the problem, or the actually cause etc & fox, please!
Would be a great help.
Cheers
Shane.
I believe glow plugs and egr, not to mention injectors can throw up this fault buddy. You need to get your car scanned to avoid playing parts roulette.
Hi thanks,
I'll have a look!
I had a garage look and he couldn't find the cause, I do recall him having a brief look at my EGR valve and he said that's all good!
Do you know if this is a common problem in Renault cars?
Cheers
Shane
