G
Are 2.0 F4R & 1.8 F4P Camshafts the same ? I know the cylinder heads are the same and the cam shafts will be interchangeable. But I don't know if they both have the same amount of lift ?
G
Discussion Starter · #2 ·
To answer my own question yes the lift between the 2.0 and 1.8 cam shafts is different not sure by how much but measuring the overall length of the lobes from rear to peak the 2.0 ones are around 0.9mm longer than the 1.8. I only compared the inlet cams.
