First off I'm new here, so Hi all!
I've spent a heap of time searching threads, but can't find a solutions to my problems and think it may be one major thing causing all of the problems I've got.
So here goes...
I've recently bought a Clio Sport 1.2 16v 2001. Here's a break down of what I've had done so far and the problems I'm experiencing.
Work done:
Full Service (sparks changed, oil changed, air & oil filter changed)
Front Brake Pads & Disks replaced
Brake Fluid replaced
Auxiliary Belts replaced
Problems:
About 5 times now, after turning the car on, the revs fall, the electrical warning light comes on and the car stalls. Turning it all the way off and back on the car does the same, but giving it a few revs seems to sort the problem.
When using the clutch and 1st gear to move (parking etc.) the clutch seems to judder and make a sort of banging sound
Power steering randomly becomes heavier then lighter, as and when it chooses
When slowing down, pushing the clutch down and putting first gear in there is a whirring down noise that seems to come from the gearbox
A few things to note are that I few days ago I checked under the bonnet and noticed the air intake pipe was torn, and then I spotted it wasn't even connected to the engine. I've pushed it back in now and the pipe is being replaced tomorrow.
One of the wheel bearings seems to be humming and my garage have advised to leave it a little longer until it is louder so they can identify the bearing at fault.
When my brakes were first changed they were super responsive as I expected. Last night I had a car full of passengers and suddenly they became significantly less responsive and have remained the same since. I'm taking it back to the garage tomorrow to have this sorted!
I've also noticed that it seems to idle at different speeds. Sometimes 500, sometimes 1000.
Not sure if anyone has any ideas if there may be something major at fault causing these problems or if it's just lots of different things due to the age of the car.
Thanks for any help in advance!
So here goes...
Work done:
Problems:
