1 - 1 of 1 Posts
Renault Laguna Dynamique 2004 2.2 Auto 35000 miles
An intermittent fault which first appeared around October 2010.
When the key card is inserted with the gear lever in Park position, the gear lever locks in the fully forward position, the dash indicator shows R and the car will not start. Fault can be rectified by rocking backwards and forwards
However at random intervals, which could be immediately after a failure or hours or days afterwards and irrespective of the number of times it has been successfully started or the mileage driven, the fault will occur again and the car will not start.
My Renault main dealer has been unable to repeat the fault. They have re-programmed to muli function switch and adjusted the brake travel
Fault happened to me 3 times since 16 March
Any suggestions please
1 - 1 of 1 Posts
