HELP
my scenic automatic moves off ok in drive , then wont select the next gear untill the revs reach 4000 , then when it changes ,it keeps selecting and deselecting any ideas?:confused:
First thing you MUST do is check the fluid level. It requires the correct and adequate amount of fluid to create sufficient pressure in the torque converter.
The experts can explain it better than I.
