21 - 27 of 27 Posts
Captur 2017 1.5DCi EDC
Directly to the wipers?? or into a Body Control Module shared with the wipers and other systems (rain sensor for example).
EDIT - take a look here at post #20
It's been a day of learning for me. I would be getting some contact cleaner onto those two wires as a first step.
I can't believe I never knew what that terminal was. I need to be a bit more careful next time I try to charge a battery in situ.
Discussion Starter #23
To the wiper motor as per wiring diagram
Sexy at 71 super mod..
Was on the early kia's but later models of the Venga have not got it..step in the right direction.. YES !!!
Did you get to the bottom of this? I have been reading elsewhere (not Renault) that a faulty battery sensor can cause all sorts of problems from non-starting to load shedding on wipers, fans etc.
Discussion Starter #26
So sorry my bad on this one. Turned out to be the Battery Management Module on the battery negative pole. I bought a new genuine item £80 that has been changed from my original unit, everything is now working as normal. Whether this is an updated part?
I believe the Renault Captur had a similar problem and there was a fix, but I don’t know if this it was this new style BMS module. Any way happy days, no need to burn the car, it was simple in the end. Word of warning, I bought a used item from a breaker and it didn’t work at all and put the spanner on and gave a constant 13.5v the same as if you disconnect the plug.
I hope this can be of help to others, and big thanks to everyone that contributed👍
Thanks for the the update. One more solution to add to the list. I think we will be seeing this more often. Expensive little items for a small pcb and a couple of contacts.
21 - 27 of 27 Posts
