my car want start sounds like battery starting an turning over but wont fire up been told i may need too bleed it how do i go about doing this??? its a x reg renault clio sport??? 1.7 ltr thanks ..
G
Attach a pipe to the drain valve on the filter housing, put that in a jar with enough diesel in the bottom to cover the end of the pipe and then open the bleed vlave and squeeze the bulb to pump the diesel though until there are no large bubbles.
When was the fuel filter last replaced?
