hi there,i have a scenic dynamique 1.8,with the blowers on full there seems to be nothing blowing out of any of the vents no matter what position i set it on ie fooywell,screen body etc.i can hear the it blowing but nothing is coming out any of the vents,the car is a 52 plate if this helps,any suggestions greatly appreciated,many thanks.
Could be a blocked pollen filter. If you set the controls to "recycle" do you then get any air ?
I assume your model has climate control and hence is controlled by a microprocessor. It may be worth resetting the processor by disconnecting the car battery for a few seconds. Make sure you know the radio cade first.
