Hello all, my first post.
I have a megane 3 I-music tourer (10 plate) which refuses to pair with my new motorola gleam+ phone, but does pair with my son's blackberry.
The fail message appears on the radio panel as soon as the phone takes the pairing option.(it sees the radio OK and pairs successfully with my laptop)
I have refreshed the Arkamys code to 2.30 and believe the motorola bluetooth level is 2.1.
I believe all bluetooth releases are designed to be backward compatible, so what can the problem be?
Thanks in anticipation, Bill
Discussion Starter #2
I seem to be in an empty room, however if anyone comes across this - Season's Greetings.
I upgraded the Arkamys software again from 2.30 to 2.42, but the displayed bluetooth software level stayed the same at 84.15.
I can't find information on what that means or what profiles are active.
The motorola phone is at BT level 2.1 +EDR ; A2DP, which is the 'alleged' simple setup with stereo configuration.
Needless to say the symptoms are the same, as soon as I activate "pair" on the phone, the Arkamys posts a fail message.
Anyone out there making progress or got any advice?
