Recently bought missis 06 clio, the boot well is filing with water.
The water is clear suggesting its run off after rain
I've also read as many other issues reported on here and still not cured it.
I have tried sealing everywhere I can and it still appears
I've sprayed talc about and the only answer I can find is it's coming up through this hole (highlighted in pic)
Before I jump the bandwagon and seal it I am trying to u understand what water would be under there ?
180288
That next door to the wheel arch?
If so, any spray being thrown up by tyres will be finding its way in through that.
Dunno what the hole is for mind you, noting underneath that should have a bolt?
Update -
Probably haven't explained well, once I have sealed around lights etc I poured water everywhere and no water has come in.
I've them taken it for a drive and this is where i can now see water slopped about
Hence my question over the hole and what is below it
Many thanks
Hi, it had a rubber bung in that hole which I lost earlier today
After driving to the scrap yard to get another is where I have discovered water again.
With regards to it been from the arches u can find no leak, the water is really clean too not like off the road, plus I've just driven in the dry !!
I'm no mechanic but I am bamboozled.
Cheers
