Hi Guys
My mate has a 04 Laguna and the electric window on the drivers side has started "bouncing" when it reaches the top.
When using the one touch operation the window goes up ok, but when it reaches the closed position it will open about an inch and stop. The window then has to be inched up to the closed position. Other than that the window works fine.
Is this a regulator problem??
Some of the lagunas have a child safty device fitted to the elctric widows whereby if it detects an obstruction such as an arm, leg, branch etc it will stop and retract about an inch or so - sounds like it is coming into operation when it detects the top of the frame - looks like it has gone haywire - is the car still under warranty.:)
Should have waited a day as the question has now answered itself.
The window will now only inch up and down, so it definately looks like the Regulator. That will be £50 off ebay then!!
