Hello all,
When driving during hot conditions my 1989 Trafic develops spongy brakes that require an additional pump of the pedal. I flushed and filled with Fuchs Silkolene Dot 4 only two years/5K Miles ago. I have Wilko Dot4 fluid unopened in stock but while in Halfords today I noted both Mineral and Synthetic Fluids. Any advice regarding why the apparently heat related issue may have developed and which fluid is preferable?
Many thanks in advance of any contributions.
Not got too much in the reservoir?
Spongy brakes when hot is a common symptom of old fluid.... but two years isn't past the use by date..generally taken as 3 years.
I'd be more tempted to look at the mechanics of the brakes, clean and ensure all is free.... hot weather may just be expanding things enough to start them sticking.
My van suffered from a leaking Load Sensing Valve .... situated in the brake line just before the back axle. I think it cost around £60 - £70 for the new part + fitting but that was around 7 years ago.
From my experience if there is no loss of fluid then its the master cylinder or its seals allowing fluid to pass by.
Al
