Just purchased a first car for my daughter(Clio 1.9 diesel 1993).
The problem I need to solve for her is that when the brake is pressed the brake lights come on but also the nearside headlamp lights up.
Any ideas anyone,could it be a relay ?
Hi Amilo - sounds very like a poor connection or dirty earth in the nearside rear lamp - if the current lamp can't find a good return via its normal earth point it will try to run through a different source thus causing another lamp to light up. I suggest you check all the brake lights for adequate earth.:)
Hello & Welcome to the Forums Amilo.
Yep I would agree with Noel here an earth problem for sure.
Ottoman
Had a similar problem eons back with a 21. Traced it back to a faulty replacement brake light bulb.Good job there were two in the pack and the second one was good. Hope this helps!!
Thanks guys,I will attack the rear brake lights.
Would it be probable that the break light at fault would be on the same side as the headlight problem ?
Its nice to have help,You have saved me some time messing with fusebox relays ect.
Can anyone point me to a wireing diagram ?
I understand that it could cause problems with copywrite but a pm with a pointer to a scanned pic would be great.
