My heater has moved on to the other side and I cant figure out how to get it going again...
Ive checked all the fuses and wrestled with the trim to get the control panel off - nothing looks amiss.
There is power to the rear demister switch - it lights up - but the rest is dead - if you turn the heater on nothing happens at all.
Is this a common problem and is it a home repair job?
power at moter
You need to test for power at the motor, if there is power there then you have a defective motor.
what is the best way to test and what do u use ..my fan just died and never came back on does not work on any settings have found the resister fuse but dont know if it is broken or not but i did use a small wire to bridge the 2 out side wires to see if the fan would go but nothing ..i have been told that somtimes the actula switch that turns the fan on can brake but have never seen anyone on here with that and i dont think it will be easy to get at
