changed my pads and rotors ealier and noticed there is some play front to back on the front caliper it seems as if the guide pins are worn can you get theses from renault or is it a new caliper or is some movement normal?
Hi iam not sure on this but i would think not but at the same time i would think that a very small amount and i mean a small bit would be ok but iam not sure but i think that someone will answer your question for sure soon all the best Donald,
They're given with a separate # in the dialogys, so they should be sold separately.
When I bought such they came in a box with a sachet of grease and the rubber covers for them and ABS sensor cable holder with the cap for the bleeding bolt.
That's calliper kit for you.
Still they are intended to move in only two directions - clutch and release.
I guess you can take them out first and have a look - they're pretty hard things to wear easily.
Tourerman
The caliper guide pins are available separately from Renaults.
thanks guys there is definate play there i suppose it could be the bores also ill pop into renault and get some guides
