Dear all
sorry if this has been posted before but i am a newbie and am not fully convese with the correct protocol of the site yet.
guys i have a 54 plate megane 2 96k on the clock i have owed since 6k i had the cam belt changed 30/12/09 15 months ago or 20k miles from my main dealer, i have had the engine warning light on for as long as i can remember as well as the service light but it runs fine, well i finally took it the car to be tested on a machine and the errors came back as such
fault memory
valve component fault
0340 cambelt sensor circuit valve outside limits intermittant
0340 cambelt sensor circuit camshaft tooth event present
0340 cambelt sensor circuit phaser measurment outside range present
0340 cambelt sensor circuit performance problem intermittant
any ideas guys as i was quoted £400 to put right for a cam belt that should last 5 years and 72000 miles ?
do reneault give any warranty with this type of work ?
to be honest i am getting fed up with the amout of issues lately from what has been a very good car, it still runs perfect etc
thank you all in advance for you replies
kind regards
Martin Burlock
fault memory
kind regards
Martin Burlock
