Hi all
I have a 99 Clio 1.2 8v which the cambelt snapped (71k miles) as I pulled up to a set of traffic lights, I am assuming I have probably bent some valves
Anyway I removed the old cambelt remains, and the top pulley appeared to be at TDC with the pulley marking at the top
I turned the bottom pulley (via rotating the wheel hub) so that the notch was at the bottom and fitted the new cambelt
Refitted all the covers etc and alternator belt (I left off the aux power steering belt just to try the car to see if it would start
The car turns over but doesnt start, so to check I took spark plug number one out, to make sure it was actually sparking, and when I turn the engine over, and what looks like petrol vapour shoots out of cylinder 1 and what appears to be some compression
Chances are I have some bent valves, but dont really want to strip the head down just yet (and have bought a Clio 1.4s to replace it anyway)
But with bent valves would the car start but be quite chuggy and misfire etc, or would it just not start at all as the symptoms above
Have I put the new belt on correctly and is it worth getting a compression tester just to check the cylinders to check before I make a plunge and strip it down
Cheers
Steve
Cheers
Steve
